AirFiber24 consuming over 150W
sundial - Member
I have an AirFiber24 that is supposedly consuming 155W on Port 2 with 48VH. I have reboot the switch and the AF24 multiple times with the same result and upgraded the switches firmware to 1.4.7. Cable tests are good.
Re: AirFiber24 consuming over 150W
Your current sensors are blown on that port.
At this point the repair is easy and cheap, I am assuming the current sensor(s) was blown from ground current. It is possible the current sensor(s) failed in which cases if the switch is within the warranty period the repair is free but will not know until we see it.
Assuming it is blown from ground current this is from not bonding the tower grounds rods to the electrical service ground rods and or the electrical service ground rods are in poor or insufficient condition in which case I suggest adding 1 or 2 new ground rods to the electrical service ground rods and bonding them all together.
Ground current is the #1 cause for WISP equipment damage. SInce we repair UBNT airFIBER and MIMOSA radios we see the exact same damage to them as our switches.
This is how to RMA the switch: http://forum.netonix.com/viewtopic.php?f=6&t=1259
This is how to get an RMA for some radios: viewtopic.php?f=21&t=2827#p19482
