36VDC versus 24VDC or 48VDC
David Lee
Has thanked: 3 times
Thu Nov 16, 2017 3:31 pm
I'm in a situation where I have space for 3 - 12V DC batteries. Will I have issues with 36 V DC vs a 24 V or 48 V battery system.
Re: 36VDC versus 24VDC or 48VDC
Thu Nov 16, 2017 3:35 pm
What model switch? If the DC model switch has a variable input DC power supply then any voltage between the min and the max will work.
Julian
Thu Nov 16, 2017 3:37 pm
Haven't heard of any such issues. From an engineering perspective, power supply efficiency is optimal around 24V and up.
I'd be willing to bet that the only way you'd ever know there was a difference would be that I told you, though, it's fairly minimal.
Been thanked: 158 times
Thu Nov 16, 2017 4:02 pm
36 volts is fine.....
David Lee
Fri Nov 17, 2017 6:43 am
Gentlemen, thanks for the imput. I'll be using a WS-26-500-DC.
Users browsing this forum: No registered users and 26 guests
