Hi Guys looking for some advice here.
We have many netonix switches and love them however we are having some funny issues that i am looking for advice on.
We have three sites in this example A - B - C. Site A is connected to site B via NEC ipasolink, site B is connected to site C by AF5x.
Layout of testing goes like this
TIK CCR - NEC - <> - NEC - WS12250DC - AF5X - <> - AF5X - WS12250DC - TIK CCR
If we test from site A to C we generally see 290 udp and about 170 tcp, if we test from site A to B or site B to C we see UDP and tcp same speeds at full of links ~290mbps with a CCR plugged into Netonix and or end of NEC link.
We run this exact same setup at another site but instead of using WS12250DC switches we use POE injectors and there is no TCP degrading so it leaves me to think there is a config issue going on here.
Flow control is turned off on all devices and switches after many tests - all port speeds at 1gbps.
Thanks for any advice.
Netonix switches on 1.4.7 (site B) 1.4.6 (site C). AF5X 3.2.2 in both tests.
Thanks!
WS-12-250-DC AF5x low TCP over multiple hops - FC??
- kodotech
- kodotech
Re: WS-12-250-DC AF5x low TCP over multiple hops - FC??
Show me config TABs for Switch at site B:
Status, Ports, VLANs
If Port Descriptions does not explain what is plugged into each port make sure you list what is plugged into each port.
On a side note why are you running v1.4.7 instead of v1.4.8rc12
"rc" is a hold over and does not mean Release Candidate.
v1.4.8rc12 has all the bugs fixes since v1.4.7
in the future after v1.4.8 we will stop using rc releases which are basically just FAST bug fix releases.
Meaning if we released v1.4.7 on Monday and Tuesday someone reported a bug and we fixed it we would release v1.4.8rc1 on Tuesday.
