Hello Forum,
After skimming the "List of POEDEVICES..." thread, it's unclear if a wiring modification is needed to power a particular IP network cam compatible with POE. I'm currently using a TP-DCDC-1248GD POE but want to power the IP Cam directly from the Netonix switch so I can utilize its power features. The TP-DCDC-1248 specs are here:
http://tycononline.com/TP-DCDC-1248GD-G ... p_129.html and it appears that this will work.
Has anyone tried to power this particular device on a netonix switch (WS-12-250-dc)
48V POE
Option @.75A - constant draw can surge/spike to 1A:
802.3af/at MODE B pinout
You would use this option to power most 802.3af/at devices like IP Phones and Cameras
Pair 3 / PINs 4, 5 are
POSITIVE
Pair 2 & 4 / PINs 3, 6, 7, 8 are
NEGATIVE
POE to StarDot/NetCamSC from WS-12-250-DC
Re: POE to StarDot/NetCamSC from WS-12-250-DC
Yes use 48V POE option - should be fine
- erik@marinaware.com
Is it possible to power the Axis M3025-VE POE camera directly from the WS-12-250? Or is an adapter required?
https://www.axis.com/files/datasheet/ds ... n_1607.pdf
I am configuring/testing a system that would combine Ubiquiti AP's and Axis cameras for security in marinas, when I came across your products.
Any suggestions are appreciated...
- Julian
Should require just 48V selected on the port, 802.3af spec is 44-57v @ power sourcing equipment.
If you have success, please comment on the list of POE devices thread, and I'll get your camera added to the list for the next guy.
Thanks!
Thanks!
