Vlan Bleed?
plankanater
Vlan Bleed?
Fri Oct 20, 2017 1:28 pm
I recently did an Unifi install with a mixture of edge switches and Netonix switches. The unifi have 4 vlans on them vlan 6 for management and vlans 3,4, and 5 for the SSIDs. Vlan 6 is untagged and the others are all tagged into the AP.
Somehow the Unifi are pulling their DHCP off of tagged vlan 5 not untagged vlan 6. I have limited this to only the netonix switches.
If I set vlan 5 to excluded, then the Unifi pulls off of vlan 6 like it should.
I am at a loss. I have ingress filtering on all the edge switches but I can not find such a setting on the Netonix.
All switches are running 1.4.7
Thanks,
Re: Vlan Bleed?
Fri Oct 20, 2017 3:06 pm
VLAN config and trunk config would help.
If using trunk port mode with "0-4095" value, it allow in ingress all VLAN ID so, to do ingress filtering, only allow VLAN needed on the trunk port or don't use trunk and tag only needed VLAN on the port.
