Hi:
Is the MSTP ready? It has already been tested by someone?
Thank You.
MSTP
Re: MSTP
From my test, per port cost and priority don't work. The switch will beavior like RSTP for every instance.
P.S.: Eric, I'm have waiting for fix to test for the last 4 month if I remember well.
Eric Stern - Employee
- Been thanked: 130 times
Re: MSTP
Fixed problem with MSTP setting priority and path cost - RC10
I didn't saw it. I'll will try it out soon
nasked - Member
- Been thanked: 3 times
Re: MSTP
Hi:
I'm going to test MSPT at laboratory before configure at my land.
If possible, attach me some pictures of your switchess and your scenery.
Thanks.
Thanks.
Re: MSTP
3 netonix in ring. I'm looking if I can change root path beharvior but from my test, MSTP priority don't work so it beavior just like RSTP.
viewtopic.php?f=17&t=2747&start=60
nasked - Member
Re: MSTP
I just finish to test MSTP on my laboratory. It seems to work fine. Now I going to implement it at my real scenery. I will send my reports.
Re: MSTP
Have you try priority on MST instance ? If so, did you use Netonix as root switch ?
nasked - Member
Re: MSTP
Hi:
I'll try to explain it with my poor English.
My scenery is a ring with 3 netonix.
1.- Root Switch (Swtch A)
Select CIST option. Name and Revision must be the same in all switches.. Root Switch priority must be lower ej: 28672
Select Ports enable then must connect with others switches.
Finish
2.- Switch B and C
Select CIST option. Name and Revision equal than Root Bridge. (Ej: Name:test Revision: 10), and check enable ports.
Select MIST instance 1. Write Vlan list. (Vlans is use in each switch)
Select MIST instance 2. Write Vlan list. (Vlans in standby)
Finish.
Advice: don't forget set trunks with all vlans in all switches...
in case to use a utiquiti link put configuration simple, and select vlan manage (put Vlan ID inside box)
If you have any problem i can send you screen shots.
Now i going to test with 4 switch... i'll report test.
Finish
2.- Switch B and C
Finish.
Advice: don't forget set trunks with all vlans in all switches...in case to use a utiquiti link put configuration simple, and select vlan manage (put Vlan ID inside box)
Re: MSTP
Have you tryed to have a different master bridge than the root bridge of CIST on instance 1 ?
Have you try to make the traffic pass via an other uplink for instance 1 ?
