Change VLAN Management
- gasparmenendez
Hi folks, the company I work for recently bought a WS-8-150-AC Switch and I'm trying to configure it, in fact, my problem is that I can't access to it from a remote location inside my LAN. I already set up an ip address (192.168.20.139) that belongs to vlan 230 and vlan 230 is in trunk mode... but I can't access to the Switch from inside my LAN, the only way is just directly connected to it and that's not an option since the Switch is going to be in a remote site. Can anybody help me please?? Thanks in advance.
- Julian
Re: Change VLAN Management
Can you post up a screen grab of your VLAN, Device/Status, and Device/Config TABs?
To upload pictures to the forum use the "Upload attachment" link below the BLUE submit button.
the management IP only responds on whatever VLAN is at the top of the list, if that's at all helpful.
- gasparmenendez
thank you my friend, I already solved!!! just changed the vlan ID for the one I needed.
Thanks!!
Thanks!!
