Management VLAN
troy
Management VLAN
Thu Sep 28, 2017 9:04 am
Have a WS-12-250-AC rev F running 1.4.7. Need to change from VLAN 1 to VLAN 301. Untagged on all ports except 13.
Current VLAN config. Pretty basic stuff.
Code: Select all
 "VLANs": [
 "ID": 1,
 "Name": "Management",
 "Enable": true,
 "PortSettings": "UUUUUUUUUUUUEU",
 "IPv4_Enable": false,
 "IPv4_Address": "",
 "IPv4_Netmask": "",
 "IPv6_Enable": false,
 "IPv6_Address": "",
 "IGMP_Querier": false
 "PortSettings": "EEEEEEEEEEETTE",
 "Enable": true,
 "Name": "Backhaul",
 "ID": "301",
 "IPv4_Enable": true,
 "IPv4_Address": "172.23.250.5",
 "IPv4_Netmask": "255.255.255.0",
 "IPv6_Address": "",
 "IGMP_Querier": true
So, I went into the GUI (too chicken to try a config from the CLI yet) and removed 301, set Management to 301, with ports 1-12 untagged, 13 tagged. The switch didn't seem to like that:
Code: Select all
Sep 28 08:27:20 UI: Configuration changed by admin (xx.yyy.zzz.nn)
Sep 28 08:27:20 UI: VLAN 1 ID: changed from '1' to '301'
Sep 28 08:27:20 UI: VLAN 1 PortSettings: changed from 'UUUUUUUUUUUUEU' to 'UUUUUUUUUUUUTU'
Sep 28 08:27:20 UI: VLANs: removed 'Backhaul'
Sep 28 08:27:24 admin: removing lan (eth0.301) from firewall zone lan
Sep 28 08:27:28 admin: adding lan (eth0.301) to firewall zone lan
Sep 28 08:27:32 admin: adding lan (eth0.301) to firewall zone lan
Sep 28 08:27:33 STP: set port 1 to discarding
Sep 28 08:27:33 STP: set port 2 to discarding
Sep 28 08:27:33 STP: set port 4 to discarding
Sep 28 08:27:33 STP: set port 5 to discarding
Sep 28 08:27:33 STP: set port 6 to discarding
Sep 28 08:27:34 STP: set port 11 to discarding
Sep 28 08:27:34 STP: set port 12 to discarding
Sep 28 08:27:34 STP: set port 13 to discarding
Sep 28 08:27:34 STP: MSTI0: New root on port 2, root path cost is 200000
Sep 28 08:27:34 STP: set port 2 to learning
Sep 28 08:27:34 STP: set port 2 to forwarding
Sep 28 08:27:34 STP: set port 12 to learning
Sep 28 08:27:35 STP: set port 12 to forwarding
Sep 28 08:27:35 STP: set port 12 to discarding
Sep 28 08:27:35 STP: set port 5 to learning
Sep 28 08:27:35 STP: set port 5 to forwarding
Sep 28 08:27:35 Port: link state changed to 'down' on port 13
Sep 28 08:27:35 STP: set port 12 to learning
Sep 28 08:27:36 Port: link state changed to 'up' (1G) on port 13
Sep 28 08:27:36 STP: set port 13 to discarding
Sep 28 08:27:36 STP: set port 11 to learning
Sep 28 08:27:36 STP: set port 11 to forwarding
Sep 28 08:27:36 STP: set port 6 to learning
Sep 28 08:27:37 STP: set port 6 to forwarding
Sep 28 08:27:37 STP: set port 4 to learning
Sep 28 08:27:37 STP: set port 4 to forwarding
Sep 28 08:27:37 STP: set port 1 to learning
Sep 28 08:27:37 STP: set port 1 to forwarding
Sep 28 08:27:39 STP: set port 13 to learning
Sep 28 08:27:39 STP: set port 13 to forwarding
Sep 28 08:32:30 admin: Reverting to last known good configuration
Any suggestions on how to change the management vlan? I have no choice but to pass 301 tagged on port 13.
Thanks!
Julian
Re: Management VLAN
Thu Sep 28, 2017 9:08 am
so, in the GUI, the top VLAN (no matter what it is) in the list is the one your management IP will be available on - You could've just moved 301 up above 1, with I think different results?
troy
Re: Management VLAN
Thu Sep 28, 2017 12:07 pm
Got it. Had to remove 301 first, then changed management to 301 without issue. For some reason, it didn't like doing both at the same time.
