A couple of our switches have a PC plugged into them. Everything is fine, except we receive the "unexpected link change" notifications from the switch when the PC is switched off and the NIC goes into power save/WOL mode and reduces to 10M (or increases to 1G).
Is there a way we can disable this notification for the PC ports? We could change settings on the PCs to keep them at 1G, or put another switch between them and the NX switch, but would rather not.
Running a few different versions, including 1.4.7 and all exhibit this behaviour.
Unexpected link change on PC ports
- scottb
Eric Stern - Employee
- Been thanked: 130 times
Re: Unexpected link change on PC ports
On the Configuration tab in the SMTP section click the gear beside the Test button and uncheck "Link Change" to disable the link change notifications.
