Hello Forum,
Is there a quiescent power consumption table I can refer to for at least the WS-8-150-DC switch?
Thanks again!
Adam
WISP switch quiescent power consumption
- Julian
Re: WISP switch quiescent power consumption
Adam -
I did a quick search, and not finding anything, decided to get out the test equipment.
Powered by my bench supply, with no traffic load, 4 RJ45 ports linked, and 2 copper SFPs populated, my ammeter reads .14A(+/-) @ 49.1V.
0.14A * 49.1V = 6.874VA = 6.874W.
no SFPs and a single port linked reads .11A (+/-), resulting in 5.401W
So, we "say" to budget 8-10w, but your actual quiescent consumption is often lower, just depends on what's plugged in, and what what's plugged in is doing. hope that helps!
kennaster - Member
- Has thanked: 15 times
This is perfect! Thank you very much!
AK
AK
