After trying to install v1.0.6 of Netonix Manager on Debian I noticed that some of the end/completion scripts have failed to run.
Namely: /var/lib/dpkg/infonetonix-manager.postinst
Uninstalling the package: /var/lib/dpkg/infonetonix-manager/prerm also fails.
Since the package fails to fully install/uninstall I've had to delete the /var/lib/dpkg/info/netonix*, /opt/netonix-manager/ and the netonix manual files before I could re-run netonix-manager 1.0.5 installer.
Unfortunately at this stage I haven't compared the files from 1.0.5 and 1.0.6, however manually running them (mainly .postinst) fails as the service won't run.
It could be as simple as invalid file permissions if anyone can look into it further?
Netonix Manager 1.0.6 issues in Debian.
- kiwista
Eric Stern - Employee
- Been thanked: 130 times
Re: Netonix Manager 1.0.6 issues in Debian.
It needs to be installed as root.
- kiwista
- Julian
Kiwista:
this post details a fix for your issue with 1.0.6: viewtopic.php?f=6&t=1549&start=160#p20997
