CURRENT SWITCH
quadra
Has thanked: 3 times
CURRENT SWITCH
Tue Sep 26, 2017 12:05 pm
Hello
We have a question about a power failure and charging on a 12v battery
I explain that our switches are connected on batteries and in the event of power failure the POE turns off and the battery remains at an emergency load of about 30%
However the WS-DC 8 OR 12 switch consumes a low energy of about 0.4 Ah ... :-|
Can the LEDs be turned off to conserve the remaining charge of a battery?
Or do you have a solution to save the maximum current at each long power outage ... :screwb:
Thank you
Re: CURRENT SWITCH
Tue Sep 26, 2017 4:29 pm
THe WS-12-250-DC and the WS-26-500-DC will go into hibernate mode at the voltage you tell it to and will only consume about 0.1 watts in this mode
The WS-8-150-DC does not offer this hibernate feature.
If you want to conserve power on long outages use the WS-12-250-DC or WS-26-500-DC
