Hello All,
I'm looking to see if there are any plans in the works for the WISP switch to support TACACS for AAA. If not is there a way to enforce authentication of documenting/accounting the commands issued by a user on the switch via something like a Syslog server.
Thanks in advance for the help.
Ryan
Feature Request: WISP Switch TACACS Support
- ryan.odonovan
Re: Feature Request: WISP Switch TACACS Support
There a linux library for TACACS+ support so it could probably be done.
https://sourceforge.net/projects/tacplus/
But I would not expect it fast if accepted since the team seem busy on new devices comming soon. Every currently implemented feature like MSTP and ERPS seem on hold for serveral month now.
Edit: Some doc from cumulus linux that could help a TACACS+ implementation.
https://docs.cumulusnetworks.com/displa ... ACACS+Plus
Dave - Employee
- Been thanked: 159 times
yes, sorry, we are working on 8 new models to release, so we are running around with our heads cut off lately...
- ryan.odonovan
Hi All,
Understandable, I will review the suggested linux library with my SysOps team to see if we can get it sorted out. If it were to be accepted what would be a realistic time frame? 1stQ 2018?
Thanks for the quick reply's on my post BTW. Much appreciated.
Ryan
Ryan
Dave - Employee
seems reasonable..
- ryan.odonovan
I'm new to working with these WISP switches so was wonder how I might get access to the code base to implement and submit for future TACACS support.
Thanks again.
Ryan
Thanks again.
Ryan
Your not suppose to but could always go into the linux CLI and check what you can do. Just type "cmdline" in the switch CLI.
- ryan.odonovan
If/When we have a working setup for TACACs; how would I go about submitting for the feature to be added? is there a process I need to follow?
Thanks again all for the assistance.
Ryan
Ryan
I would write to Eric in private about this.
Eric Stern - Employee
- Been thanked: 130 times
I'll add it to my list of potential new features.
