Will RMK-250 fit the WS-10-250-AC?
- uberdome
- Experienced Member
- Has thanked: 3 times
- Been thanked: 11 times
Will the WS-10-250-AC accept the RMK-250 rack ears? It has the same dimensions as the WS-12-250-AC... so I figured I'd ask.
- Julian
Re: Will RMK-250 fit the WS-10-250-AC?
Yep, not much of a difference between the two chassis.
uberdome wrote:Will the WS-10-250-AC accept the RMK-250 rack ears? It has the same dimensions as the WS-12-250-AC... so I figured I'd ask.
Julian wrote:Yep, not much of a difference between the two chassis.
NO - THE RMK-250 DOES NOT WORK ON THE WAS-10-250-AC
- Julian
They're the right size. Thing is, on the 10, there isn't anywhere to put the screws, which I never noticed. Go figure.
- uberdome
I was getting back into this project and see the WS-10-250-AC is not on the website any longer.
Is it discontinued / is it being replaced?
The WS-10-250-AC is EOL
The unit did not sell well as more people wanted either the WS-8-150-AC or WS-12-250-AC so this unit was dropped to help make room for newer models coming out Q1 2018.
- uberdome
Thank you, I'm looking forward to the updates.
