How to protect my laptop?
OOLLC
Thu Sep 07, 2017 3:05 am
Just a little concerned about blowing out the ethernet port on my laptop. Is there a "best practice" method for connecting to these switches with my laptop?
Julian
Re: How to protect my laptop?
Thu Sep 07, 2017 7:31 am
Most laptops are transformer isolated, as cat5 typically builds up some kind of DC bias anyway, but you can use a USB Ethernet NIC such as this one: http://bit.ly/2vNNwEF
I'm not saying it's best practice to plug your laptop into a live 48VH port, but I've done it unintentionally and haven't smelled any smoke.
Thu Sep 07, 2017 10:11 am
There is an LED on every port that is Green for 24V, Blinking Green for 24VH, Red for 48V, Blinking Red for 48VH.
Why not just NOT plug into a port that has POE turned on at all? Rule of thumb if there is a light on the empty port that means do not use this port.
Thu Sep 07, 2017 3:06 pm
A serial cable and at less learn the commands to shut down PoE on a port if your not confortable with CLI.
