DC Power Calibration
LRL
Has thanked: 19 times
Been thanked: 49 times
Sat Aug 26, 2017 6:16 pm
Does the calibration affect all aspects of decisions made based upon voltage such as the 150w limit on low voltage?
-LRL
Julian
Re: DC Power Calibration
Mon Aug 28, 2017 7:27 am
Short answer, Yes.
Longer answer, software calculates DC Vin, and the calibration is a change in the function that calculates it - ergo, the variable called when looking for input voltage should return the modified value.
Are you having an issue with it?
LRL
Mon Aug 28, 2017 1:09 pm
When submitting the calibration form all ports get powered off and then back on. Figured it was related to some of the protection stuff.
-LRL
Julian
Mon Aug 28, 2017 1:31 pm
Well that's not supposed to happen.
Eric has been apprised, I believe a fix is in process for a subsequent release.
