How to power a SAF Lunima radio
yoder
Been thanked: 9 times
Tue Nov 18, 2014 10:13 am
Chris,
You have said several times here that you are powering your SAF radios with the WISP Switch. How are you doing the cableing since these radios aren't POE?
Keith
Re: How to power a SAF Lunima radio
Tue Nov 18, 2014 10:18 am
SAF has different types of radios, some are POE some are split that use co-ax cable to connect the two units
Obviously I am talking about their outdoor units ONLY which are passive POE like the SAF-106 and SAF LUMINA
The SAF 106 takes 48V and the LUMINA uses the 48VH ports
yoder
Tue Nov 18, 2014 1:50 pm
We use the Lumina radios here and I was under the impression the RJ-45 port wasn't POE. So far we have always run a power cable from our -48 power supply.
Our SAF radios are actually manufactured locally here in Brazil. They come in Siemens boxes. There might be some hardware differences.
In one case we are using a FO cable between our router and the radio because there was something goofy going on with the ethernet cable. It would only connect at 10 Mbps.
Keith
Tue Nov 18, 2014 1:54 pm
The SAF 106 and Lumina Radios I have or seen are the total outdoor units that use copper.
If you have a split version or the version that uses Fiber then I do not think we can power those.
Well after looking at the new brochures from SAF maybe they LUMINA is only available with a separate power cable and not POE
I will have to investigate making an adapter box/cable to allow POE maybe?
yoder
Tue Nov 18, 2014 2:23 pm
An adapter box would be cool. I have a tower location that has the following:
4 SAF Lunima radios
1 AirFiber24
8 AirMax radios.
3 Mikrotik routers
If I could power this with one switch that would be awesome.
Keith
Tue Nov 18, 2014 2:26 pm
well we only have FOUR 48VH ports in the A models of the switches both 12 and 24 ports but you have 5 high power devices.
4 SAF
1 airFIBER
5 48VH devices
rockhead
Has thanked: 53 times
Been thanked: 35 times
Tue Nov 18, 2014 3:28 pm
sirhc wrote:well we only have FOUR 48VH ports in the A models of the switches both 12 and 24 ports but you have 5 high power devices.
4 SAF
1 airFIBER
5 48VH devices
looks like its fourth and long @yoder time to punt :ak: , I'll just be waiting for a saf or AF to come downfield now :willy:
either that or @sirhc needs to change his approach to ... with 4 high power ports per switch you'll have room to grow with three available ports when you deploy two switches
Tue Nov 18, 2014 3:52 pm
rockhead wrote:... with 4 high power ports per switch you'll have room to grow with three available ports when you deploy two switches
Well there you go... problem solved! Sweeping
wayneorack
Has thanked: 188 times
Been thanked: 64 times
Tue Nov 18, 2014 5:00 pm
4 SAF
1 airFIBER
5 48VH devices
I understand that it is nice to just plug into the switch! But, I bet you did get a POE injector in the box with every radio. And I doubt many people are using this type switch at a DC site.
Tue Nov 18, 2014 7:07 pm
Well we do have a small form factor 8 and 12 port coming out soon.
We also have DC versions of the 8 and 12 port small form factor as well as the 12 port rack mount.
We are not sure about the 24 port yet.
Our DC versions will accept between 6 and 60 V DC and we measure the input voltage and current from the battery bank as well as the current draw of the POE devices and switch. Lots of power monitoring!
Our small 12 port version also does have 2 SFP ports + 12 copper ports with POE and can power 4 airFIBERS.
Our small versions are about the same size as a ToughSwitch
