Hi Guys,
Just wondering if it's possible to add in the DHCP Snooping code the ability to inject DHCP Option 82 as well, this would serve us well with some clients that we hand off directly at some PoP's.
RFC is as attached https://tools.ietf.org/rfc/rfc3046.txt
Brendon
DHCP Snooping with Option 82 Injection
- bdallen
sakita - Experienced Member
- Has thanked: 110 times
- Been thanked: 90 times
Re: DHCP Snooping with Option 82 Injection
I'm also in need of DHCP relay.
There's a Firmware Roadmap thread which includes this and other ideas...
viewtopic.php?f=17&t=295&p=17961#p17961
Eric Stern - Employee
- Been thanked: 130 times
- bdallen
- bdallen
Hi Guys,
Dont mean to be a bother but how is this progressing?
It would be awesome to have the unit in the Circuit ID field have injected the Ingress Port + VLAN when using QinQ to customers.
No ETA at this time. This is actually going to be a lot of work and there is not a lot of demand so unfortunately that makes it low priority.
- bdallen
Bummer, would have been something awesome to have in the near future. I need to get hold of the mikrotik guys they did it half baked
(No Snooping, Doesn't add bridgeport when set on a bridge so all circuit id's are the same)
