Power Stats on website about switches
wnoc - Member
It would be nice to see more detailed info on the website about the max power draw of the switch itself with no devices plugged in for when trying to calculate the load for sizing batteries... I know each model has a max like 250W, or 400W... But that's the max if everything is plugged in, it would be nice to know what the wattage is for each device by itself so if you combine the switch and a couple of radios you can get the max wattage you need...
1 post
