I would like to know the minimum power consumption in watts for the WS-8150-DC? I need to calculate the power consumption for additional equipment at an existing off grid DC site. The site runs at 24V. I was going to add the minimum power consumption of the switch to the maximum power consumption of the radios I want to deploy to get a baseline power consumption rating.
Mark
Minimum power consumption WS-8-150-DC
admin@aligntec.net - Member
Re: Minimum power consumption WS-8-150-DC
THis has been discussed many times - SEARCH FEATURE IS AVAILBLE
But why not simply hook the switch up and just login to the UI with no ports selected it is telling you how many watts it is using.
The switch will use anywhere from 4-8 watts using no POE on any port depending on how many ports are active and link speeds and if the fan is running.
