AF4X - 48VH?
zrob_12 - Member
AF4X - 48VH?
Will a AirFiber-4X handle 48VH over about a 100ft cable run? I know that 48V works okay.
Re: AF4X - 48VH?
zrob_12 wrote:Will a AirFiber-4X handle 48VH over about a 100ft cable run? I know that 48V works okay.
Here is the teach a man to fish concept.
Please explain to me the difference between 48V and 48VH.
zrob_12 - Member
Re: AF4X - 48VH?
0.75 vs 1.5 - I am aware of this. The unit comes with a 24v 1A POE...I want to make sure that I don't damage an expensive unit or switch
Re: AF4X - 48VH?
zrob_12 wrote:0.75 vs 1.5 - I am aware of this.
It's not about the total amps the port can deliver. A car battery can easily deliver 100 amps but the small bulbs in the dash don't burn out.
The reason VH ports can deliver more amps is because they use all 8 wires so can spread the current over twice as many wires. The PoE brick that ships with the AF4X also uses all 8 wires to deliver 24V.
zrob_12 - Member
Re: AF4X - 48VH?
zrob_12 wrote:That being the case, then 48VH should be okay?
As far as I know all AFX radios can use 48VH
But yes the MAIN difference between 48V and 48VH as Les said is 8 wires verses 4 wires caring power.
NEVER use 24VH on ANY airMAX radios
NEVER use 48VH with a Titanium rocket
READ THESE THREADS
viewtopic.php?f=6&t=1215
zrob_12 - Member
Re: AF4X - 48VH?
Thank you.
Just tried to switch the AF4X to 48VH with no luck (but it did not damage anything). I can confirm that 48V works though.
Re: AF4X - 48VH?
zrob_12 wrote:Thank you.
You cannot switch from 48V to 48VH directly because the switch sees link. You need to turn off PoE first so the radio drops link.
