Bounce a port via SSH
jjonsson - Associate
- Has thanked: 37 times
- Been thanked: 65 times
What is the complete CLI command to bounce f.ex. port 4 now for 10 sec. ?
- Has thanked: 362 times
- Been thanked: 87 times
Re: Bounce a port via SSH
- Code: Select all
cmdline
touch /tmp/poe_override/4
Works the same as the GUI
You'll see this in the log:
- Code: Select all
Jul 18 07:27:45 switch[1364]: Port 6 Link: changed from poe override
Great!
But how long does it bounce ?
Immediately off/on, 10 sec. or ?
For 10 seconds - just like the GUI
Just tested with a device and timed it.
- VMSystems
Forgive my ignorance...
The first command you type in the SSH window is "cmdline"
then
"touch /tmp/poe_override/4" for port 4
then
