Compatible SFP Modules - FIRST POST IS COMPILED LIST
Wed Nov 12, 2014 11:53 am
I want to start this thread so people can report which SFP modules work and do not work with the WISP Switch.
Please specify the SFP manufacturer and model number and share if it works or does not work.
Keep in mind reports of some SFP modules early in the thread were fixed by firmware patches reported to work further down in the thread.
I do suggest when using an SFP module to fully put it through the paces before putting in service.
Insert SFP and get a link.
Do a warm reboot in the UI/CLI (same as a firmware upgrade reboot) make sure the link comes back up.
Do a cold boot (power cycle) and make sure the link come back up.
If it fails try setting port speed to both Auto and then 1G and see which works better with that module.
If it still fails try another SFP module, maybe same brand and then another brand and test again.
WORKS:
10Gtek GLC-T
10Gtek SFP-T
Addon SFP-SX
Avago AFCT-5765ATPZ
Avago AFCT-5717APZ
Ciena XCVR-A10Y31
CISCO DS-SFP-FC-2G-SW
Cisco GLC-LH-SM
CISCO GLC-SX-MM
CISCO GLC-ZX-SM
Cisco SFP-H10GB-CU5M
EB-Link J4858A/B/C
Fiberstore SFP-1GTA-1M
Fiberstore SFP-GE-BX
Fiberstore SFP-GB-GE-T
Fiberstore SFP-10G-DAC (.5m)
Finisar FTRJ8519P1BNL-J2
Finisar FTLF9519P2BNL
Gencom GLC-BX-U
Gencom GLC-BX-D
GigaLight GE-GB-P1RC & GE-GB-P3RC (gigabit RJ45 SFP)
GLC-SX-MM
GLC-ZX-SM
GLS-SX-MMD-A0
HP J4858B
HP J4858C
LongLine GLC-T-LL
Maxwave MW-1513-SM-US
Maxwave MW-1315-SM-US
Maxwave MW-LX-SM-US
Maxwave MW-SX-MM-US
Maxxwave MW-UTP-G-US
Mikrotik S-3553LC20D
Mikrotik S+DA0001r2
Mikrotik S-31DLC20D
Mikrotik S-85DLC05D
Mikrotik S-35LC20D
Mikrotik S-53LC20D
NCOM GLC-T
Netgear AGM732F-R
OSIOptics GLC-BX-D-20KM-OSI
Planet MGB-TLX
Proline Generic HP SFP J4859C-CDW
ROBOfiber SFP-7000-85
SFP-LX-1
Telecoast GLC-BX-D-20-TC
TP-Link TL-SM311LS
UF-MM-1G
SORTA WORKS:
Cisco CAB-SFP-50CM - Netonix to Netonix interconnection works, Cisco to Cisco interconnection works, Netonix to Cisco not so much
Fiberstore BLSFP-1G53-20-CO (disable FC while module inserted, starts working, if reseated, won't initialize)
Fiberstore BLSFP-1G35-20-CO (disable FC while module inserted, starts working, if reseated, won't initialize)
GLC-T-OEM (requires reseating after rebooting)
GLC-T-LU (not sure, thing stopped working entirely, pretty sure I broke it)
Mikrotik S-RJ01 (does not work with all models?)
Mikrotik S-85DLC05D (conflicting reports)
SFP TL-SM321A/B (connection works, UI shows false no link)
DOESN'T WORK (confirmed):
Alcatel Lucent 3FE
Finisar FTLF1318P3BTL
Level One SFP-3211
NCOM GLT-T (works a couple hours, then quits)
OEM GLC-BX-U-00
OEM GLC-BX-D-00
Oersen SA1
RB-FTC-11
Volex VAHS-28-0029
Mikrotik S+DA0001 (early revision)
UF-SM-1G-S - (Would like another person to weigh in on this one)
Pirate6
Netonix modules tested
Wed Nov 12, 2014 11:58 am
Works fine:
Addon SFP-SX
NCOM GLC-T
CISCO GLC-SX-MM
Addon SFP-LX-1 - NOW WORKS WITH v1.0.5rc1
Addon GLC-SX-MMD-A0 - NOW WORKS WITH v1.0.5rc1
CISCO DS-SFP-FC-2G-SW - NOW WORKS WITH v1.0.5rc1
Does not work:
nelson05
Has thanked: 11 times
Been thanked: 11 times
Re: Compatible SFP Modules
Wed Nov 12, 2014 11:26 pm
We are starved for ports on one of our WISP Switches. Rather than fiber, we were looking at adding copper SFPs to get us two additional ports. It sounds from your description that this is an issue limited to optical SFPs. Should I assume that any copper SFP is safe? Anyone have any specific models they have used before I go out and place an order for a couple?
Wed Nov 12, 2014 11:42 pm
I have yet to have any problems with copper nor have I heard of anyone else - YET?
Rory
Fri Nov 14, 2014 2:44 pm
Just a quick note to anyone looking at Cisco compat sfp modules. Quite a few modules that have DDM or DOM are labeled with a D as the last letter of their model. There are some exceptions to that rule, but you can check against this list:
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_8031.htmlWhile the Cisco documentation may not always be 100% from my experience, I would consider that list a good resource if you are trying to avoid DOM / DDM. Also that list contains many modules that I'm sure we don't support (10Gig for example) so please keep in mind that I am not saying we support everything or even most of the modules listed. But if you have a gigabit sfp in mind that is cisco compat, you can check the list to ensure it does not have DOM capabilities.
LRL
Has thanked: 19 times
Been thanked: 49 times
Sun Dec 07, 2014 4:39 pm
AMC Optics GLT-T - Works Fine
Mikrotik S-3553LC20D does not work
Mikrotik s-31dlc20d does not work
-LRL
billbuchan
Has thanked: 42 times
Been thanked: 34 times
Mikrotik S+DA0003 'SFP Connect'
Sat Dec 20, 2014 12:15 am
This is sold as 'MikroTik SFP+ Direct Attach Cable - 3M' - for example: https://www.msdist.co.uk/product_MikroT ... ble-3M.php
Its basically a hardwired copper 10gig SFP+ module, which also works in an SFP cage. I've got one plugged into my WISP router (250B), and the other end in a Mikrotik 260 switch. Both ends report the link as live, active, etc. Both ends appear to push data, the wisp switch is apparently not receiving any data.
However, I can't 'ping' the other device (from either device).
EG.
Wisp Switch - IP address 10.100.11.2
Mikrotik Switch - IP address 10.100.11.3
No VLAN setup, etc, all ports forward to all ports.
And yet ping doesn't work between them (either from the Wisp switch web management page, or from a device plugged into ether switch).
Am I doing something particularly stupid? WISP switch firmware is 1.0.9 and Mikrotik is 1.14 (latest). Both got pulled out of boxes two hours ago.
Any help gratefully received,
--* Bill
LRL
Sat Dec 20, 2014 12:56 am
The wisp switch doesn't support SFP+ (10Gb)
-LRL
adairw
Has thanked: 98 times
Been thanked: 132 times
Sun Dec 21, 2014 12:24 am
I bought some Mikrotik RJ45 SFP copper module's that do 10/100/1000 with auto negotiation (S-RJ01) and they work fine in the WISP Switch. Just FYI.
mayheart
Has thanked: 48 times
Been thanked: 60 times
Sun Feb 08, 2015 1:18 am
Using Telecoast/GLC-BX-D-20-TC SFP, working no problem.
