I know in the video it shows LACP enable and using two ports but is this even capable on this router and the Netonix switch?
Is there a tutorial? I don't see anything specific to mikrotik and how to do this if its even possible.
LACP Mikrotik CCR 1009-7G-1c Router
- Accel Wireless
Re: LACP Mikrotik CCR 1009-7G-1c Router
Link Aggregation Control Protocol (LACP) is part of an IEEE specification (802.3ad) that allows you to bundle several physical ports together to form a single logical channel.
LACP allows a switch to negotiate an automatic bundle by sending LACP packets to the peer.
Since we follow the standard I see no reason for us to produce a teaching manual on LACP as there are tons of material on the web to read how it works.
As far as other device support that depend on the device. "Most" routers do not support LACP such as a Cisco "router" but is supported in Cisco "switches" which is why in my video I say I am using "STATIC" LAGs between the Netonix switch and the Cisco 2951 routers at my towers.
MT though is not a normal router and I believe they support LACP but you need to refer to them on that.
A GOOGLE search of LACP:
https://www.google.com/search?q=LACP&rl ... e&ie=UTF-8
