Hi all, just had my Netonix WS-12-DC randomly reboot about 2 hrs ago... Nothing really in the logs that I could see. Any idea what that might be about? What should I watch for next time? I cleared the log so that if it dies again, it will hopefully be neater and cleaner...
I just put this switch into production Saturday afternoon... So just a few days ago.
WS-12-DC Random reboot?
- deerefanatic
Re: WS-12-DC Random reboot?
Well if the switch reboots the Log is cleared so not sure what you plan to gleam from the log other than the boot process?
You need to use a Log Server to have record of a reboot.
you have told us very little information as to help you other than your unit rebooted?
Describe your tower setup:
What are you using to power the switch?
What firmware version are you running on the switch?
Does your location have AC power, if not explain what you have?
How far from your tower ground rods are the electrical service ground rods?
Are the Electrical service ground rods bonded to your tower ground rods?
Please pust up screen grabs of your TABs so we can see your configuration.
