Hi, Everyone.
Has anyone encountered this error? I don't see why the error comes up with port 25 when this is a 12 port switch. The switch doesn't loose the connection. It just looks like a root bridge election, but I downstream switch priority is pretty low. This doesn't drop the connection.
firmware = 1.4.7
board rev = F
power supply = 53
power supply rev = B
Jun 23 10:23:24 STP: MSTI0: New root on port 25, root path cost is 20000
Jun 23 10:23:24 STP: MSTI0: New root on port 5, root path cost is 60000
Jun 23 10:23:24 STP: set port 13 to discarding
Jun 23 10:23:24 STP: set port 13 to learning
Jun 23 10:23:24 STP: set port 13 to forwarding
Jun 23 17:44:45 STP: MSTI0: New root on port 25, root path cost is 20000
Jun 23 17:44:45 STP: MSTI0: New root on port 5, root path cost is 60000
Jun 23 17:44:45 STP: set port 13 to discarding
Jun 23 17:44:45 STP: set port 13 to learning
Jun 23 17:44:45 STP: set port 13 to forwarding
Jun 24 09:43:46 STP: MSTI0: New root on port 25, root path cost is 20000
Jun 24 09:43:46 STP: MSTI0: New root on port 5, root path cost is 60000
Jun 24 09:43:46 STP: set port 13 to discarding
Jun 24 09:43:46 STP: set port 13 to learning
Jun 24 09:43:46 STP: set port 13 to forwarding
Jun 25 11:32:10 STP: MSTI0: New root on port 25, root path cost is 20000
Jun 25 11:32:10 STP: MSTI0: New root on port 5, root path cost is 60000
Jun 25 11:32:10 STP: set port 13 to discarding
Jun 25 11:32:11 STP: set port 13 to learning
Jun 25 11:32:11 STP: set port 13 to forwarding
Jun 25 22:37:14 STP: MSTI0: New root on port 25, root path cost is 20000
Jun 25 22:37:14 STP: MSTI0: New root on port 5, root path cost is 60000
Jun 25 22:37:14 STP: set port 13 to discarding
Jun 25 22:37:14 STP: set port 13 to learning
Jun 25 22:37:14 STP: set port 13 to forwarding
WS-12-250-DC STP
- phongc@smwd.com
- Has thanked: 3 times
Re: WS-12-250-DC STP
I think the first SFP port is numbered 25.phongc@smwd.com wrote:I don't see why the error comes up with port 25 when this is a 12 port switch.
sakita - Experienced Member
- Has thanked: 110 times
- Been thanked: 90 times
Yes indeed: First SFP Port = 25, Second SFP Port = 26...
http://forum.netonix.com/viewtopic.php? ... 7412#p7412
- phongc@smwd.com
