It's working great, just wanted to report :)
It replaced some Mikrotik gear, which was working okay, but not gigabit. I really like this unit, seems like it's just built for WISP use, which is a big difference...very happy so far :)
Really loving this WS-8-250-DC
- silverstr8p
- Has thanked: 3 times
Re: Really loving this WS-8-250-DC
Thanks, you did upgrade the firmware though right? Should be running v1.4.7 or v1.4.8rc4
The new v1.4.8rc4 has a calibration feature to calibrate the input voltage reading.
- silverstr8p
I was running 1.4.8rc3, should I upgrade, or wait for stable release <next>?
silverstr8p wrote:I was running 1.4.8rc3, should I upgrade, or wait for stable release <next>?
Your call.
All rc4 does is give you the option to calibrate the input voltage to make it more accurate as some people complain it can be off "a little".
- silverstr8p
IDK the normal release interval, any indicators of when the next stable release might be?
silverstr8p wrote:IDK the normal release interval, any indicators of when the next stable release might be?
We do not do firmware releases like everyone else.
Read this post:
viewtopic.php?f=6&t=2461&p=18994&hilit=+firmware+bug+release#p18994
- silverstr8p
I did the upgrade and it seems to work fine. I'll check back every once in awhile to see if there are more, but right now seems okay :)
