Hello all,
Does anyone know how to do a fast or rapid ping from the GUI or shell of a Netonix switch?
Thanks in advance,
Keith
Rapid Ping
- SYS7EM-Keith
Re: Rapid Ping
Well if your in the CLI you can drop to linux with the "CMD" command + [Enter].
Then it is a case of being a Linux method.
You type "Exit" + [Enter] to return to the CLI
Re: Rapid Ping
Busybox, use by Netonix and most embedded linux based devices, don't support the -i option to set a lower interval. Busybox cut several option and build supported command in the shell to save space.
