VoIP Priority
VoIP Priority
Wondering if VoIP priority is set automaticly on the switch or if it needs to be set in the CLI?
Eric Stern - Employee
- Been thanked: 130 times
Re: VoIP Priority
It is not set automatically. You might be able to prioritize it with a rule on the QoS tab in the UI if you can find a reliable way to identify VoIP packets.
Re: VoIP Priority
Also note that it will be priorised locally, not on attached devices like wireless radio. So, if your bottle neck is a radio, mostly the case for WISP, then don't expect QoS on the switch to fix VoIP quality issue.
