WS-12-250A
quadra
Has thanked: 3 times
WS-12-250A
Fri Mar 10, 2017 2:31 pm
Salut a tous
pourquoi le WS-12-250A à disparu ?
merci :crazy:
Julian
Re: WS-12-250A
Fri Mar 10, 2017 2:39 pm
We replaced the 12-250a with the ws-12-250-AC or WS-12-400-AC.. is there a particular feature set you were looking for?
Re: WS-12-250A
Fri Mar 10, 2017 2:40 pm
It was EOL and replaced with the WS-12-250-AC which is smaller and has more POE options.
Basically same switch in a smaller box with more features.
People complained the WS-12-250A and B were too big to fit in boxes
So we took the same switch and made it smaller with more options and same price.
quadra
Re: WS-12-250A
Fri Mar 10, 2017 3:23 pm
Ok merci pour vos réponses ....
donc oui effectivement nous allons prendre 1 WS-12-250 AC ou 400 à la place,
j'ai juste une petite remarque à faire sur le 400 et le 250 AC c'est que l'alimentation 220 v est devant , du coup c'est moins esthétique dans une baie info ... :screwb:
mais bon c'était juste un petit petite critique ....... :leave:
Users browsing this forum: Baidu [Spider] and 92 guests
