Port bonding on WS-12-250-AC
- AllenHilbert
I have been searching the forums for days on this topic and wasn't able to find anything definite on it. I know that you can bond ports on the MT routers rather easily just wondering if you can bond ports on the switch. Any help would be appreciated on this. Thanks in advance!
Allen Hilbert
Fastlink Communications
Re: Port bonding on WS-12-250-AC
What Layer 2 switches support is LACP and Static LAGs
These are industry standard protocols so Google LACP and STatic LAGs to learn how to use them and you configure them under the LAG Tab
LACP & Static LAG - https://en.wikipedia.org/wiki/Link_aggr ... l_Protocol & https://en.wikipedia.org/wiki/Link_aggregation
Here is a list of posts where LACP is discussed on the Forums
search.php?keywords=%2BLACP+%2BGoogle&terms=all&author=sirhc&sc=1&sf=all&sr=posts&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
Users browsing this forum: Baidu [Spider] and 92 guests
