OK, I searched, and searched and could not find anything about this before I get my head chewed off.
I have a WS6mini powered by a WS-12-250AC
I have been running cameras and a nanobeam for several months.
Today I noticed 2 cameras are down, They have no POE applied (off), when I try to select a voltage the drop down items are greyed out.
Any ideas?
WS6 Mini Unable to select voltage
canpandave - Member
- Been thanked: 4 times
canpandave - Member
Re: WS6 Mini Unable to select voltage
btw, there have been no changes except I upgraded the WS6 Mini to the latest 1.4.7rc8
Try downgrading and see what happens, could be a missed bug in rc8?
A greyed out POE option should only occur if the port has a link already as why would you want to apply POE to a port that has a link?
- Has thanked: 15 times
- Been thanked: 10 times
On a WS-6MINI upgrade from 1.4.2 to 1.4.7rc8 I am not seeing this issue. This is on a pretty default WS-6MINI powered by a WS-12-250AC. No POE was set on the WS-6 before the upgrade and nothing is connected to it besides the cable from the 12-250
CP
CP
- Julian
could just be coincidence- will attempt to duplicate when time allows,
what flavor of firmware had you been using?
I have PoE on ports 2 through 5 on my MINI running the latest RC8 powering 3 cams and a UAP. Not seeing an issue.
Try a factory default then manually setup
Users browsing this forum: Baidu [Spider] and 86 guests
