Automated Config Backup
- Rory
One thing I was thinking of is that my cisco's are all configured to backup the config to a tftp server anytime I do a write mem. That would be a great feature, regardless if it supported tftp, ftp, sftp, smb, or even email. Automated config backups serve not only as an easy way to replace failed hardware, but a good reference in the event that someone misconfigures a piece of hardware.
- Has thanked: 31 times
- Been thanked: 136 times
Re: Automated Config Backup
I should add that the backups should be unit agnostic (unlike mikrotik) so it's simple to drop in a backup on a new/replacement unit!
JimBouse - Member
- Has thanked: 16 times
- Been thanked: 3 times
I run a FTP server for this exact reason on my network.
Each Mikrotik FTPs to the ftp:\\server\deviceName-Internet.Protocol.Address.Number\Date-Time.cfg each night. This gives me a record of each router each night.
JimBouse wrote:I run a FTP server for this exact reason on my network.
yeah, but configs dont drop directly in on 'tik. Both the 'backup' utility and export command produce configs w/ hard coded MAC addresses. You have to 'sanitize' the config before dropping in onto new hardware :/ lame.
rkelly1 - Experienced Member
- Has thanked: 12 times
- Been thanked: 27 times
rebelwireless wrote:JimBouse wrote:I run a FTP server for this exact reason on my network.
the backup files on MT drop right in on a new device as long as the device is the same and the operating system version is the same.
or they mangle up the bridge-local and wlan1 because of different MAC addresses.
JimBouse - Member
Ahem... /export compact instead of /export
It doesnt include the mac when you use the compact switch
maglito - Member
email the backup config as an attachment on config change (or just on demand) would be nice, I could setup a TFTP server too but email is already working so well on these.
I use a similar feature via script on all my mikrotik stuff and it works great.
Example: email script for mikrotik
I schedule that script to fire off weekly on my mikrotik stuff and believe this is a pretty common practice.
Just an idea for future firmware.
- Code: Select all
/export file=export
/tool e-mail send to=my@email.com subject="$[/system identity get name] export" body="$[/system clock get date] configuration file" file=export.rsc
Our switches offer TFTP backup every time you save a new config, turn it on under Device/Configuration Tab
