Thanks for getting me the 12 Port and the phone call today! I got it fired up and played around with the GUI a bit. This thing is legit man! I can't believe how quiet this bad boy is. I plan to take this to our hilltop that has 7 AP's and a backhaul! Only part I'm bummed about is the inability to power my Exalt 11Ghz with this thing.
I cannot wait to get my hands on the 24's for my office. We'll be replacing our Toughswitch Carriers and Smart switches for sure!
In love with this thing!
Re: In love with this thing!
WisTech wrote:Thanks for getting me the 12 Port and the phone call today! I got it fired up and played around with the GUI a bit. This thing is legit man! I can't believe how quiet this bad boy is. I plan to take this to our hilltop that has 7 AP's and a backhaul! Only part I'm bummed about is the inability to power my Exalt 11Ghz with this thing.
Thanks man, I am so nervous on how you guys will like it!
How do you power your Exalt radio?
WisTech - Associate
- Has thanked: 9 times
- Been thanked: 64 times
With a standard 802.3at injector.
PS - Keep up the good work man. I'm just stoked to finally have this in hand. It'll be on it's way out to our heaviest loaded hilltops here soon!
WisTech wrote:With a standard 802.3at injector.
Well then it should power the radio? I power my SAF radios with the switch. Just verify the pin out polarities and you should be fine!
WisTech - Associate
Awesome. I didn't see anything listed about 48V at. I'll double check and give it a whirl! We'll only use airfiber, exalt's or rocket AC's for backhauls so it sounds like this freaking switch is the ticket!
WisTech wrote:Awesome. I didn't see anything listed about 48V at. I'll double check and give it a whirl! We'll only use airfiber, exalt's or rocket AC's for backhauls so it sounds like this freaking switch is the ticket!
You have the Model WS-12-250A which means the first FOUR ports support 48VH which is for powering high power 48-50V units that use all 8 wires for increased current like airFIBER, SAF, EXALT.
On the WS-12-250A and the WS-24-400A that is a POE option on ports 1-4 whereas the B Models only support this on ports 1-2.
48VH PoE Ports
Pins 1,2,4,5 (+)
Pins 3,6,7,8 (-)
1.2A
However do NOT power high power/current radios on the other 48V ports (5-12) or even on these ports unless you select 48VH as they only inject power on pins 4,5(+) 7,8(-) (2 pair) only and the radio will attempt to draw to much current on only 2 pairs and could damage the radio and or the switch.
48V PoE Ports
Pins 4,5 (+)
Pins 7,8 (-)
.5A
WisTech - Associate
You're the man, and you deserve a pat on the back bud!
I must say I just put v1.0.1 on my tower switches today and I LOVE THESE THINGS TOO!!!
I even upgraded one tower twice just to see how fast the tower came back, AWESOME FAST!!!!
Now consider my towers use airFIBER 24 units as in and out back hauls using OSPF and before the radios all went down with a switch firmware upgrade so the tower was down several minutes....now a firmware upgrade is less then 20 seconds until the switch boots and OSPF sees the adjacencies up across the airFIBER unts and BAM back in business!
I wonder if we are the only POE switch that keeps the POE ports up during a reboot so the radios do not have to reboot and re associate client radios?
v1.0.1 fixes a lot of stuff we had wrong with v1.0.0 all the way up to v1.0.1rc16 SOOOO MUCH BETTER NOW!
WisTech - Associate
Just loaded 1.0.1, AND my other 12, and two 24's showed up today! Thanks again Chris, you're the man! Now that I have a 'spare' 12, I can deploy this one on the hilltop I talked to you about with the Exalt.
