PING...
jjonsson - Associate
- Has thanked: 37 times
- Been thanked: 65 times
PING...
When SSH'ing to switch I need to run continous PING. Is that possible ? Can figure out the exact command (so probably not possible ?)
Eric Stern - Employee
- Been thanked: 130 times
Re: PING...
At the CLI use "cmdline" to drop to the command line. Then "ping <ip address>". CTRL-C to stop.
Re: PING...
Odd, I get continuous ping.jjonsson wrote:That gives me 5 PINGs, not continuously PING....
Re: PING...
Sorry..... Got into busybox. Wasn't aware I had to type >cmdline<.....
It's working perfectly now with continously PING
