The reset-configuration-changes on the UI is FAR too aggressive.
I've had several occasions which my phone rang or something, causing the switch to reboot because I didn't click "save"; or the fact that it's impossible to change the IP address to something unreachable.
For example, I'm setting up a switch in the office to take to the site. I assign the IP address for the permanent installation. The switch will now reboot because the IP isn't reachable on the local subnet.
Sure, there are ways around it; but it's just annoying.
There should be some mechanism to bypass this test and simply unconditionally apply.
Product Feedback
Re: Product Feedback
There is, simply disable Revert Timer to 0
viewtopic.php?f=6&t=1258&p=15961&hilit=+revert+timer+0#p15963
