Using WS-12-250-DC's on several towers and love them. The only hitch, is we monitor the voltage of the Mikrotik routers at the sites to warn us if the voltage is dropping at the site. The WS-12-250-DC sends the same power to the units no matter the input voltage and i have my MPPT solar controllers set to disconnect at 22V's. Is there a way for the Wisp switch to send an email when the input voltage drops below a certain voltage? Maybe i can get my Dude server to monitor the input voltage, i have not tried that approach. Either would work.
Anybody got an idea?
Tommy
Tommy A.
Network Admin
Digitex.com
Email when input voltage drops
- Digitexwireless
Tommy A.
Network Administrator
Digitex.com
Tommy A.
Digitex.com
Re: Email when input voltage drops
well yea
first off I hope you upgraded firmware to v1.4.6
second, yes, look on the Power Tab and configure alert for input voltage (must have SMTP properly configured on the Device/Configuration Tab)
You can also use SNMP to query the switch for input voltage
- Digitexwireless
I am still running the RC but was going to do the upgrade soon. Figured I might need to drive out onsite if there is a problem. I will give that a try, i did not see it on the RC, but will look again.
Thank you.
Tommy A.
Network Admin
Digitex.com
Thank you.
Tommy A.
Network Admin
Digitex.com
Tommy A.
Digitex.com
Tommy A.
Digitex.com
Digitexwireless wrote:I am still running the RC but was going to do the upgrade soon.
Which RC version, not a big help there saying RC version, but there were some SNMP and other important fixes in v1.4.6.
- Digitexwireless
1.4.3rc7
Tommy A.
Digitex.com
Tommy A.
Digitex.com
Yea, pretty OLD firmware, update ASAP
- Digitexwireless
will do.
Tommy A.
Digitex.com
Tommy A.
Digitex.com
