We are currently running out of room in some of our Cabinet's due to having so many Fibre Media Converters,
We are resorting to using Mikrotik CRS's in these locations, but the Netonix Switches are a lot easier for Configuration and Management that the CRS.
Is there any future plans to develop a similar thing to the 212-1G-10s-1S+IN?
Mike
SFP Switch Possiblity
MichaelBrandl - Member
- Has thanked: 4 times
Re: SFP Switch Possiblity
For future planning, using fiber instead of copper is the unstoppable trend. The 212-1G-10s-1S+IN comes with 1 Gigabit Ethernet RJ45 port, 10 SFP cages and 1 10G SFP+ cage, as well as LCD panel and serial port (RJ45). Maybe you should find a Netonix switches that can support up to 40G. Or there are many other vendors can support the similar switches like D-link, Netgear, or even Cisco. Good Luck !
TP-Link have a cheap 12 ports model that is far from Netonix simplicity, but also not a pain to configure like those CRS.
