WS-8-DC--Is input voltage shutoff configurable?
gripper - Member
I wonder if this can be configured to protect batteries?
Re: WS-8-DC--Is input voltage shutoff configurable?
gripper wrote:I wonder if this can be configured to protect batteries?
Umm Yea, look at the Power Tab.
I suggest you take 15 minutes and explore all the Tabs in the switch UI.
gripper - Member
Don't actually have a DC switch, or I would have looked there first. I'm particularly interested in whether one can set, e.g., a 21 or 22V low voltage cutoff, so as not to take a 24V battery bank down into damage range.
You can find a lot of information on this forum with the search box or advanced search by clicking on the magnifying glass in the search box.
Post likes these:
viewtopic.php?f=14&t=898&p=6801&hilit=+depth+discharge#p6801
viewtopic.php?f=6&t=1255&p=9311&hilit=+depth+discharge#p9311
viewtopic.php?f=6&t=1321&p=9767&hilit=+depth+discharge#p9767
Post likes these:
gripper - Member
Those certainly address the question, thanks. Next time I'll search a little deeper before I ask.
--Jeremy
--Jeremy
