Storm Control Settings
- keefe007
What are the recommended storm control settings in terms of PPS?
Re: Storm Control Settings
That is an open ended question and based on your network.
For instance I have a completely routed network and never leave customers have layer 2 access to my network so I have it disabled.
If you have a small or large flat segment will make a difference to the values you use.
I would Google each type of traffic and learn what they all do and how much traffic of each type would be normal for your network based on your normal traffic levels then add maybe 50^ or even double the value.
But that would be me, everyone runs their networks differently and has a different topology so this is not easily answered as a one size fits all.
- keefe007
Eric Stern - Employee
- Been thanked: 130 times
Storm control is based on the number of packets on a physical interface and so is not affected by VLANs.
mhoppes - Associate
- Has thanked: 10 times
- Been thanked: 125 times
It is by port though - not total on switch correct?
mhoppes - Associate
So how long does it block for? Or just until that limit reduces?
mhoppes - Associate
Is there a way on the switch to see the current number of unicast broadcast etc packets going through?
mhoppes wrote:So how long does it block for? Or just until that limit reduces?
It indiscriminately drops any packets over the specified storm limit.
mhoppes wrote:Is there a way on the switch to see the current number of unicast broadcast etc packets going through?
That would be a nice feature if Eric could do it.
