SPF Port Capability
FastNetUS
SPF Port Capability
Wed Oct 19, 2016 12:53 pm
I have replaced my TSW8 with a WS-12-250-AC about a year ago and have not looked back. One thing I am wanting to do is see if I can bring my fiber connection in through the SPF port to eliminate the media converter I have now with Ethernet bringing circuit into the switch.
Re: SPF Port Capability
Wed Oct 19, 2016 1:00 pm
Well yes the SFP ports support 1G fiber, not sure what you're asking exactly?
FastNetUS
Wed Oct 19, 2016 2:22 pm
I only have found where is say uplink to support airfiber. I would assume it would but just wanted some verification before I tried it and caused an issue. I currently am using Azotel and have it between the Wisp switch and the media converter. Was just trying to eliminate some equipment if I could and bring the fiber circuit directly into the switch.
Wed Oct 19, 2016 2:58 pm
FastNetUS wrote:I only have found where is say uplink to support airfiber. I would assume it would but just wanted some verification before I tried it and caused an issue. I currently am using Azotel and have it between the Wisp switch and the media converter. Was just trying to eliminate some equipment if I could and bring the fiber circuit directly into the switch.
Yes
