Correct me if i am wrong but i do not see anything in the switch to change the management vlan.
Currently our setup is
1-7 Untag vlan 10
tag vlan 172 1-7
tag 8 on both because its our uplink.
we can see everything just fine we just cant see the switch.
Management VLAN
- shiftenterprises
Re: Management VLAN
We have a search box which will help you find things already discussed and answered, such as these posts:
viewtopic.php?f=6&t=1572&p=11646&hilit=default+vlan#p11646
viewtopic.php?f=6&t=1570&p=11639&hilit=default+vlan#p11639
viewtopic.php?f=17&t=241&p=13915&hilit=+management+vlan#p13915
viewtopic.php?f=17&t=287&p=12278&hilit=+management+vlan#p12278
- shiftenterprises
Re: Management VLAN
You know that was kind of rude, yes i know you have search function and yes i did try that before i posted to not have a reply like that. Is it possible that you can add an easier way to change the switches management vlan?
Re: Management VLAN
shiftenterprises wrote:You know that was kind of rude, yes i know you have search function and yes i did try that before i posted to not have a reply like that. Is it possible that you can add an easier way to change the switches management vlan?
I am not trying to be rude, I simply made the assumption that you either did not know about the search box or possibly that you did not think to use it as I easily found those posts with the exact same question you're asking?
So my options were to ignore your question since I had already answered it many times or point you in the right direction.
I am a firm believer in the whole saying about teach a man to fish and he eats for life.
If you read the posts I gave you above they explain how to change the management VLAN ID and and Description, I am not sure where your confusion is then?
So big deal we require the FIRST VLAN definition to always be the management VLAN but you can change the ID and Description, where is this a limitation?
