Netonix WS-24-400A Stop trafic
cepaveca
Wed Sep 28, 2016 8:30 am
Alguien ha usado, en los Netonix la posibilidad de apagar un equipo a determinada hora y volverlo a encender, a determinada hora. Como les funcionó ? En mi caso, lo hice en varios puertos de un mismo Netonix (WS-24-400A), a la misma hora y activacion un minuto despues. Pude observar que, luego de ese evento, el Netonix deja de andar. Los equipos que se apagaron, estan nuevamente activados, pero sin poder traficar.
Lo notaron ?
Habrá alguna solucion ??
English
Someone has used in the Netonix the ability to shut down a computer at a certain time and on again, at a certain time. As they worked? In my case, I did in several ports of the same Netonix (WS-24-400A), at the same time and one minute after activation. I could see that, after that event, the Netonix stops walking. The AP´s (all they) went out, they are again activated, but could not works. They noticed?
are there any fix ?
Ricardo from Argentina
Re: Netonix WS-24-400A Stop trafic
Wed Sep 28, 2016 8:39 am
I am sorry for the language barrier but your going to have to try and explain this again as I am not quite following you.
What firmware version are you running?
Show a screen grab of your configuration Tans being used to achieve your goal.
Always include the Main Status and Device/Status Tabs as well.
Users browsing this forum: No registered users and 89 guests
