Install and Configure 2 New WS-8-150-DC
joebocop
Fri Jul 22, 2016 8:05 pm
I have just received a new WS-8-150-DC device, which is destined for a remote deployment scenario, and want to be sure I am correctly installing and configuring before I begin. My thanks for the guidance.
Site Specs
- 1 x Netonix WS-8-150-DC
- 1 x Ubiquiti NBE-5AC-19 (24v, 8w max power consumption)
- 1 x Ubiquiti NBE-5AC-16 (24v, 6w max power consumption)
- 1 x Ubiquiti UAPOutdoor+ (48v 8w max power consumption)
- 1 x Tycon Power PST2448-50-140 solar kit with charge controller and 24v battery confighttp://tyconsystems.com/index.php/35w-continuous/339-rpst2448-50-140All Ubiquiti gear will be powered by the WS-8-150-DC.
The charge controller included in the Tycon kit exposes a wiring block that provides "24V 35W" power, from which I intend to power the WS-8-150-DC.
How much current does the WS-8-150-DC draw? By my (crude) calculations, Ubiquiti gear will require no more than 22w, and I should have access to "35w" from the charge controller. Can the WS-8-150-DC survive in this scenario on the remaining theoretical ~13w?
Thank you again. Learning as I go here.
joebocop
Re: Install and Configure 2 New WS-8-150-DC
Fri Jul 22, 2016 8:08 pm
I see from viewtopic.php?f=6&t=1900#p14106 that the WS-8-150-DC can be directly wired to the 24v battery configuration, so perhaps that is a better option than wiring to the charge controller device included in the Tycon kit?
Again, thanks for sharing any expertise on this.
Fri Jul 22, 2016 8:25 pm
Correct, use the unregulated voltage from the batteries, Don't use the 35W regulated tap. It cuts too close to the max draw. My WS-8 was drawing almost 5 watts with no PoE load.
