Restore config.json
tonym
Been thanked: 7 times
Restore config.json
Mon Jul 18, 2016 5:35 pm
If I have a backup of config.json, what is the easiest way to restore that?
It doesn't seem to work through the ui. When I submit config.json, it doesn't seem to apply it.
It would be handy if it accepted either in the webui.
Re: Restore config.json
Mon Jul 18, 2016 5:40 pm
The backup and restore functions of the UI and CLU do not want just the config.json file they want the compressed file with directory structure that it creates during backup.
tonym
Tue Jul 19, 2016 8:47 am
Could I manually recreate that compressed file? Or do I just need to stare at the config.json and try to get things configured back how they were?
Would a tar file that just contained www/config.json work? The rest of the files seem to be password files and ssl certs.
Eric Stern
Been thanked: 130 times
Tue Jul 19, 2016 1:14 pm
tonym wrote:Could I manually recreate that compressed file? Or do I just need to stare at the config.json and try to get things configured back how they were?
That will work.
Users browsing this forum: No registered users and 23 guests
