PA-50V-65W Stock
mhoppes
Has thanked: 10 times
Been thanked: 125 times
PA-50V-65W Stock
Mon Jun 06, 2016 9:21 am
Any idea when these will be back in stock?
Re: PA-50V-65W Stock
Mon Jun 06, 2016 9:27 am
4 weeks +/-
For now we recommend people power with the AF24 POE bricks or MIMOSA POE bricks.
mhoppes
Mon Jun 06, 2016 9:35 am
Can I power 4 24volt radios off a Ubiquiti 48Volt supply though?
Mon Jun 06, 2016 9:57 am
mhoppes wrote:Can I power 4 24volt radios off a Ubiquiti 48Volt supply though?
Our barrel adapter power supply is only 50V @ 65W
The AF24 POE adapter is 50V @ 60W
There is only 5 watts difference
Depends on the radios your talking about, comes down to doing the math.
If you are talking (4) airMAX radios your fine as their "average" draw is 6 watts with peaks to 12 watts +/-
So even if you assume 4 x 12w MAX = 48 watts + 4-6w MAX watts for the switch = 54w MAX
Also you can look in the UI once it is running and see your watts usage and decide.
mhoppes
Mon Jun 06, 2016 9:58 am
Fair enough.... Thanks Chris.
Mon Jun 06, 2016 10:16 am
AFAIK Chris is also coming out with a 54V high wattage PoE brick to rival the POE-54-80W that Ubiquiti has. These are great for longer cable runs where you may have voltage drop on the 48V side plus the reverse polarity diode bridge adds 1.5V drop compared to the .75V drop on the barrel connector. Obviously voltage drop is not going to be an issue on 24V kit but on a long run you could get a few low voltage alert nags depending on firmware version.
