Plug cable then turn on POE
or
Turn on POE and connect cable/radio
Correct POE sequence?
Re: Correct POE sequence?
ginovilla wrote:Plug cable then turn on POE
or
CORRECT PROCEDURE: Plug cable then turn on POE
POE SMART if enabled with run a cable diagnostics automatically and refuse to turn on POE if a cross-short is detected
