Hi just a general question on your thoughts.
Do you normally place the WS-24-400A in a server rack or normally just mount it on a wall.
It seems quite large and was wondering if it needs to get some more air flow.
Thank you.
Netonix WS-24-400A in rack?
- nightshadow36
Re: Netonix WS-24-400A in rack?
The rack ears that come with the WS-24-400A allow you to turn them 90 degrees for wall mounting or straight for rack mounting.
Your choice, it's fine.
- nightshadow36
That was the quickest reply I have had on a forum in my life.
I know its my choice but what would you recommend?
Thank you.
Thank you.
nightshadow36 wrote:I know its my choice but what would you recommend?
sirhc wrote:The rack ears that come with the WS-24-400A allow you to turn them 90 degrees for wall mounting or straight for rack mounting.
That means either is fine, but if you have a rack that looks neater and is the preferred orientation but either is fine.
At my WISP most are vertical hanging racks which is same as wall mount.
