Is there a memory leak in 1.3.9 firmware? Seems like every time I log in and check status the memory usage is higher than last time.
WS-10-250-AC
1.3.9
Board rev. E
Memory leak?
Re: Memory leak?
There may be a small memory leak in v1.3.9
I had some switches running v1.3.9 and they were up over 100 days and yea I saw the memory higher than it should have been.
We believe all memory leaks are fixed in v1.4.0rc25
lacibaci - Member
- Has thanked: 8 times
Re: Memory leak?
sirhc wrote:There may be a small memory leak in v1.3.9
OK, given RC status I'm assuming release is coming soon, I'll wait.
Re: Memory leak?
Yes I am slated to push v1.4.0 FINAL this evening after I upgrade all my WISP towers with it.
Sometime after 9PM EST (GMT -4)
