10 port Fiber fed switch fail and then ok off for 12 hours
tcknudson
Has thanked: 4 times
Been thanked: 22 times
Wed May 18, 2016 3:19 pm
I have one location that I have replaced AC switch (WS-12-250-AC) when failed, with a 48 volt supplied unit (WS-12-250-DC) , and then it failed, Replace 48 volt supply to no avail.
One ac and one dc, after leaving each off overnight, they seem to work fine.
Not using any POE ports on either,
Was stormy when each occurred, no water got to switches, no lightning to speak of,
Any clues?
Been thanked: 159 times
Re: 10 port Fiber fed switch fail and then ok off for 12 hou
Wed May 18, 2016 3:27 pm
what firmware are you using, and what do you mean failed?
Wed May 18, 2016 3:47 pm
Was there rain?
Is the tower grounding system bonded to the Electrical service ground?
Do you have dedicated ground runs to the radios that is shorter path to Earth Ground than the Ethernet Cables.
viewtopic.php?f=30&t=188
viewtopic.php?f=30&t=1429
tcknudson
Wed May 18, 2016 5:48 pm
was rain each time but no sign of water in either switch both work fine when returned to my bench.
Wed May 18, 2016 6:04 pm
tcknudson wrote:was rain each time but no sign of water in either switch both work fine when returned to my bench.
Rain causes ground potential shifts
read these 2 posts - THE WHOLE POSTS DO NOT SKIM THEM
